Windswept
- Cardigan bay
Greetings. Another of those long-time lurkers here. We have a stone & rubble built semi built around 1860, with later additions. It was converted long ago from a larger house. The immediate problem is not really ‘period’, being a small flat roof on a lobby that joins the old and new blocks. It has started to leak, as they do, the leak exiting rather alarmingly through a light fitting. This happened during storm Darragh, dried up over the past rain-free week, and has started again as the weather returns to normal. There are a couple of small stains developing on the plasterboard ceiling but no sign of sagging or mushiness.
Plan A was simply to paint a suitable acrylic gunk onto the surface and see what happens - roofers seem to be on their hols or otherwise unavailable atm anyway. The trouble is that we / our handyman can’t see any obvious damage to the roof surface other than a bit of algae. Next step will have to involve someone going up a ladder in the rain to have another look. Tempted to push a screwdriver through the ceiling…
In the meantime can anyone spot anything from the attached photos? There are three roofs and two valleys draining onto this roof, which in these parts means a lot of water. The block on the left is a modern concerete block extension, the other two sides are the original building ( felt under the slates, probably re-roofed around 1960).
Do we need a plan B?
