Jon Maine said:3 sand, 1 lime is fairly universal, by volume, not by weight.
Non-hydraulic and hydraulic limes are both available today as dry hydrates. The former, as ‘high-calcium’ lime (generally marked ‘CL90’ to indicate that it contains 90 cent calcium lime), is usually marketed as builder’s lime, and is primarily intended as a plasticiser in cement:lime:sand mortars (1:1:4 or 1:1:6 for example) for modern masonry construction. This processed lime is not, however, a good substitute for traditional non-hydraulic lime putty or for use on traditionally constructed buildings as it does not possess the same working characteristics as traditionally slaked non-hydraulic lime putty. It is not intended for lime:sand mortars and cannot be relied on to meet the strength and durability performances required.
robgil said:i was reading that last night jon , couldn't make head nor tale of it. i shall try again when not tired and sober.![]()
so , hydrate is fine , 3 to 1 mix with sharp (preferably unwashed?) sand.
do i need to mix it today then re-mix it and use the next? or is that just with putty?
MdB said:From Jon's article, which sounds authoritative, 2:1 or 1.5:1 would be better.
