Did you install under floor heating? Is it working well? Consensus seems to be that ufh doesn't work well in older homes but I don't understand why because it should hear the floor and distribute the heat more evenly.The only thing I regret so far is that when they mixed the lime for the floor they use a plastic type of fibre for the mix and I’m sure I could’ve insisted or sourced my own non plastic fibres… also the geotextile membranes I’ve since learned that you could in fact use Hemp sacks! So that’s what I’d do if I did it again, save the plastic being in the floor!![]()
