Fair play to that guy, what a lot of work he's put in but why is he insulating the walls with PIR on batons?Your situation doesn't appear to be as bad as this guy -> https://jack-kelly.com/insulating_our_victorian_living_room
Rotting joists, unsupported load bearing wall, and failed damp proof "treatment".
If you have the entire floor up, use the opportunity to get some insulation under there.
I think most people would be confused with that suggestionInsulation is the plan.
A friend of mine has just thrown in a comment that I could really do without, which is that I may not want to have all the waste removed as it could cause the external walls to end up acting as small retaining walls. Haven't had a chance to clarify what they mean (and they do have qualifications that makes me pause to think twice about what they've said). There is no talk of excavating anything here, simply removing what's been dumped to reinstate the original. Really confused that this would suggest the waste is having some kind of structural effect now.
I'm confused if it came from an engineer. Older houses often had crawl spaces of 2 or 3ft below floor level, but the floor was usually a fair bit higher than the external ground level. It needed to be to allow for the air bricks.I think most people would be confused with that suggestion
