Optimist
- Leicestershire
We live in a probably early 19th century house that is constructed of brick at one end, stone in the middle and brick at the other end. It has been painted but someone has at some point painted with plastic masonry paint, which we know is a problem and needs removing. The only parts of the house that are damp are the brick sections, so due to financial constraints we need to focus on this initially. Am I correct in thinking a DOFF sprayer is the best option for this? Other (cheaper) suggestions are welcome. Our main problem is that the dampest end of the house is about 4m from a stream, so the water table will usually be high. We have put in a french drain which we think has helped but we still have damp but the biggest issue is that the stream occasionally in very heavy rain bursts its banks and flows past the end of the house. It doesn't come high enough to come through any doors but last winter it once came in through the wall so we would need to find a solution to prevent this happening. We need to re point a section, which is happening imminently but are told this will not stop the water coming through. We have been advised to paint the bottom with bitumen paint, but this won't help the damp. It is, in our opinion, the lesser of two evils but is there another solution? Because we are close to the source of the stream, when this happens, it is only against the house for a couple of hours before it goes down again (if that makes any difference).
