grouchy
- Gloucestershire
Hi there, I hope the great minds of the forum can help.
I have a red-brick semi built in 1912, solid 9" walls with what I believe is lime mortar pointing. Not rendered.
We've had the usual array of damp / condensation problems, I think largely caused by previous owners using modern materials and methods.
The next room on our hitlist is the lounge. We have damp (condensation?) patches on the external wall and, on one side, tracking into the internal wall too. I think the previous owners used one of those rubber-based paint-on products to about 4' up the wall; the damp patches generally start above that, either side of a chimney breast. I think there's gypsum plaster underneath but would need to disturb it to confirm. The rest of the house has the crumbly old black (lime?) plaster; it may even be that there's that beneath modern plaster.
There seem to be so many opinions on the best course of action here - and recent posts seem to espouse different views (perhaps because there are different products) to those from 5-10 years ago - that I'm not sure which is the best course.
Additional information:
I'll consider all options - cost is a factor but not the biggest factor, we just want it to look smart.
This photo shows the damp patches mentioned above. The left hand wall is the external wall, but the right hand wall is an internal (brick) wall - I'm assuming the damp is tracking into the internal wall from the external wall, but could be wrong. I don't know what the round 'bump' in the middle of the photo is beyond a small patch of blown plaster.
Thanks in advance!
- The room is on the ground floor and has a suspended timber floor with loads of gaps between the boards and no carpet (those gaps are also on my list - but appreciate they do help with ventilation). The space beneath the floorboards is externally vented through air bricks
- PVC windows are in good condition but pretty old - so no trickle vents. They are (like the rest of the house) fitted right on the inside edge of the window reveals and surrounded by a timber trim. That would make the plastering job simpler, but pulling all the trims off and resetting could be painful
- The pointing outside is all sound, and there's no obvious causes for any penetrating damp (leaking gutter etc.)
- There's nice coving around the ceiling which ideally I would not disturb
Thanks in advance!
