Pennyviz said:It is hard work but worth it I think ...
TheSpid said:might just dig it up then and pop in limecrete and UFH and put oak planks down
88v8 said:TheSpid said:might just dig it up then and pop in limecrete and UFH and put oak planks down
Noooooo :shock:
Wood is an insulator. A wood floor on top of ufh is bonkers. And If it's old wood, it will shrink and warp, if it's new engineered wood it will look crap.
Neighbours up the road did that, or rather their idiot architect did. Wood over ufh. Would be cheaper to heat the house by setting light to fivers.
Repeat after me, wood is an insulator, wood is an insulator!!
You wouldn't put fleecy jackets on your radiators, would you?
Or perhaps in your part of the world, you would. Some weird people in these far-off lands![]()
PS getting up old tile adhesive is a problem. One sees the question on trade forums, I don't think there is an easy answer, sorry. My starting point, old wood chisel, with the corners rounded off so it won't scratch.
Feltwell said:Pennyviz said:It is hard work but worth it I think ...
OOoo - lovely!
I've got a not dissimilar floor, but without the black tiles. Did you regrout those, if so what with? Mine has fortunately only ever been covered up with carpet, so apart from the inevitable gripper rod damage and where some Neanderthal hacked a pipe across the floor - luckily next to the back door, so a door mat covers it - it's not too bad. It does need regrouting though, and the tiles are quite worn & grubby in places.
Pennyviz said:Thank you! Yes the brick acid trashed the grouting. Regrouted with 3.5 and fine soft sand if I remember correctly. Then sealed with ltp breathable sealer.
Craig89 said:Pennyviz said:Thank you! Yes the brick acid trashed the grouting. Regrouted with 3.5 and fine soft sand if I remember correctly. Then sealed with ltp breathable sealer.
Out of interest is that brushed in dry?
I have read some very old tiling books that mentioned using cement mixed with water to create a slurry for the joints.
I ask because I have both quarry tiles and geometric floor tiles to fit and grout in the future.
