Pogonation
- North East
Hi I just joined this forum although have been reading threads for some time.
I wondered if I could get some advice. I have a converted apartment in a house built in 1874. The stand out room in my apartment is a large 40sqm living room with 12ft ceilings and a nice big bay window.
Unfortunately due to a leak from the apartment above >50% of my ceiling was flooded. The lining paper has been removed and revealed a wet (after 3 weeks drying), bowed and cracked ceiling. The lime has delaminated from the lathe and there is a good 1.5inch or so movement when pressing up and down. Other areas in the room are also found to have delaminated. Luckily my insurance will be covering the job.
Here is a photo although it doesn’t look too bad the plaster has separated from the lathe.
I have spoken to a heritage plasterer who has advised cutting up to the level of the cornicing and removing the ceiling. He would take a mould of the decorative strip (inset from the cornicing) and replace that. He would plasterboard the entire area to the same level as the cornicing and plaster it so it blended in with the cornicing.
I figured losing such a dense material may increase the risk of noise transmission so thought that it would be a good opportunity to insert acoustic rock wool between the joists and also use denser acoustic plasterboard in 2 layers with green glue inbetween.
I wondered what peoples thoughts are on this method of repair? Would it be suitable, or should I be looking for an alternative solution? Do you think the sound insulation methods above should leave me in the same/better situation when it comes to sound transmission from the flat above?
Thanks I’m advance for any help!
