Whilst we’re having other works done to the house, we’re thinking of replacing the original (150+ years) mains supply lead water pipe with a modern MDPE version. The house is a Victorian terrace, with the exterior stop clock just outside on the footpath and the interior stopclock about 15m further away in the kitchen.
In terms of installing the pipe, we seem to have been quoted for two options:
- Lay a pipe from the boundary that enters below the front bay window, and is run across the sub floor-void entering the kitchen below the plinth area and being connected to the existing riser. The pipe will be laid in insulation, as is mandatory for pipe that isn’t buried.
- Installation via moling wherever possible, so that the pipe is buried (I believe to a minimum of 750mm).
One of my considerations is that I want to avoid damage to the kitchen (as this doesn’t need any renovation), and we’re unsure if the moling intensive method might cause damage.
Any advice on the pros/cons of either of these two methods would be appreciated.
Finally, with regards to the pipe, is there any benefit to going with a 32mm over a 25mm?
