Hello folks, after a long period of inactivity, I’m back on the job and of course am out of my depth as usual.
You probably won’t remember, but I’ve got an 1870 house, brick built from first floor, but as it turns out ground floor is at least part stone.
I’ve just taken up some floorboards on the first floor to look at the joist ends. As I suspected, one is pretty rotten, soft and bounces. It’s on a really awkward spot in a corner with a brick wall on one side. It’s embedded into stone on the rotten end which is an external wall. The problems causing damp have been rectified-bad gutters, leaking roof, and the outside is being lime rendered in the spring to replace naff patched/cracked mish mash of all sorts. I’ll add pics below, but you’ll see an added complication is all the house wiring coming down very close to the wall. The copper pipe you’ll see is I think a dead leg from an old bedroom basin upstairs, but I’ll lift floorboards upstairs to check before removing.
I have no idea how to approach the rotten joist end. Any ideas? Many thanks! And now I’m back, I’ll be trying not to bother you too much, but will probably not be successful! Thanks all
![IMG_2659.jpeg IMG_2659.jpeg](https://www.periodproperty.co.uk/forum/data/attachments/8/8540-0162c26b5c9c02d6f532552cbd52e399.jpg)
