Platypus13
- Wrexham
Hi all,
First post, long time reader of the forums. It has been hugely helpful in tackling our renovation over the past 6 years.
Our house is a late 1700s (as far as I’ve been able to work out from old deeds etc) end of terrace cottage. Once it was a larger farmhouse which during the 1800s was split into terraces and added on to. Downstairs construction is thick sandstone walls, whilst upstairs is old soft brick on the front and back, but still stone all the way up the gable side. Seems a little odd to me but so much of this house is.
Over the past few years we removed the cement render outside, and have been removing the gypsum and cement from the inside. All going fairly well bar the odd wall collapse!
My current issue that I’m battling is in the living room. About 3 or so years ago I removed all the cement and gypsum from the walls. Let it sit for around 9 months then repointed in traditional lime. It then had 2 coats of cornerstone insulating plaster, and top coats of Clay plaster. All seemed well until after drying out salts slowly started to creep back through. The worst areas had the clay removed and re applied in the hope the clay had pulled out the worst of the salt contamination. Since then in a few areas the salt has come back and pretty much turned the clay plaster to loose dust that falls off the walls.
What’s the options here for remedying?
The worst wall is an interior wall between the living room and kitchen, but there are no pipes or anything around or above that wall that could be leaking.
Is it possible that the walls are still drying after all this time?
Are there any lime plaster additives that allow the walls to remain breathable but block salt? I assume not but worth asking.
Short of continuing to plaster and remove when slats appear, sort of like using a poultice, I’m a bit lost as to what else to try.
Thanks for any advice which you might be able to give.
