LadyArowana
No matter how many regs there are and how draconian the enforcement people will just find other strange and exciting ways to demise http://www.thesun.co.uk/sol/homepage/news/3804909/Man-killed-by-clothes-horse.html
MdB said:The thing is, Part J Section 2 Table 1 states that NO vents are required for stoves without flue draught stabilisers below 5kW in houses built before 2008. This is my house and my stove.
I've always thought that horses are dangerous beasts.LadyArowana said:No matter how many regs there are and how draconian the enforcement people will just find other strange and exciting ways to demise http://www.thesun.co.uk/sol/homepage/news/3804909/Man-killed-by-clothes-horse.html
Flyfisher said:I've always thought that horses are dangerous beasts.LadyArowana said:No matter how many regs there are and how draconian the enforcement people will just find other strange and exciting ways to demise http://www.thesun.co.uk/sol/homepage/news/3804909/Man-killed-by-clothes-horse.html
May I ask where from? I will need some shortly of the mains connected type.Moo said:.. and bought top-of-the-range alarms for us and our children.
We used to have one. It was called Peebles. One day while it was out of its cage, the kitchen door was opened and it flew away.MdB said:You do have a carbon monoxide detector don't you?
Onetap said:A room with plastic double-glazed windows and laminate floors should ring mental alarm bells.
I think that's often referred to as the Missionary method of installation, isn't it?Schoolmarm said:Is the flexible liner fitted OVER the stove pipe? Or is it the other way round? It needed to be female pointing up and male pointing down.
You use an adapter designed to convert from stove pipe to flexible liner (which does the male female bit correctly :shock: ). I can't see any good reason not to use the correct part for this job.Schoolmarm said:Is the flexible liner fitted OVER the stove pipe? Or is it the other way round? It needed to be female pointing up and male pointing down.
AhhhMdB said:You use an adapter designed to convert from stove pipe to flexible liner (which does the male female bit correctly :shock: ). I can't see any good reason not to use the correct part for this job.Schoolmarm said:Is the flexible liner fitted OVER the stove pipe? Or is it the other way round? It needed to be female pointing up and male pointing down.
