Morning all,
Onto the next issue (temp fix before we get new windows), we have two windows in main bedroom that are very drafty, not the actual glass but the fact some moron fitted them and I can see day light. Either way when I come sort it, I found the plaster board dabbed and dotted onto the widow insert (not sure what it's called) and I could feel cold air. So knocking it off. I found this.
This is a 25 old extension onto our limestone cottage. As you can see the outside walls are limestone, and breeze blocks inside. It's looks like a damp proof sheet has been inserted vertically with what I assume is loft insulation on the inner side of it, the issue is the limestone brick is damp to touch. It's also looks like a right mess and bodge city.
Can somebody suggest what to do? I was thinking filling the gaps with some lime mortar and lime plastering over, it won't be a brilliant fix but should stop the air leaks and also help reduce the moisture on the bricks, then seal outside with lime mortar, although the limestone bricks looks like they are stuck together with concrete?
Any help would be most appreciated, as another can of worms opened
Kind regards
James
Kind regards
James
