billybuntus
Sounds like fitting central heating would be a start
"Please sir, a big boy did it and ran away!"fluffytail10 said:I was running along the path holding a lump hammer and just happened to jump up and bang a hole in the wall!
With the wall that wet, it will make the humidity in the room high. I would imagine that it would then condense out again on the cold, wet walls as the air temperature rises above the wall temperature.fluffytail10 said:Upstairs, the wall is probably damp from water coming through the little cracks in the cement render, but where all the condensation is coming from is a mystery. It's only a bedroom !
I've very glad the PPUK doesn't have a "+1" or a "like" button, but I completely agree with worms..worms said:With the wall that wet, it will make the humidity in the room high. I would imagine that it would then condense out again on the cold, wet walls as the air temperature rises above the wall temperature.fluffytail10 said:Upstairs, the wall is probably damp from water coming through the little cracks in the cement render, but where all the condensation is coming from is a mystery. It's only a bedroom !
Being impatient and reckless, I'd be out with the lump hammer attacking the external render, but caution is probably a much better approach!
