Cubist
Given that at this stage you are only considering purchasing the property you are in a position where, should you consider proceeding, you might be wise to have the vendor confirm the species of timber comprising the frame and sole plate - he/she should know or may be able to share documentation that confirms this. Also, is it your intention to negotiate some kind of discount of the sale price or require the vendor to get the work done ahead of contract?
More importantly to my mind though is that sole plates can be very, very expensive to replace depending on the final extent of the damage and how much of the plate - and importantly, any collateral damage caused to the joints of any connecting posts/timbers (particularly corner posts). As others have pointed out there is a world of difference between old and modern softwoods - not least in terms of their point load bearing capacities. Careful consideration of the point loads - including snow load - transmitted to the repaired section from the structure above to ensure that the repair is capable of supporting that final weight without crushing is vital.
I would strongly underline @Kearn s suggestion that you employ a reputable timber frame specialist to assess the building and all elements of the frame before going to contract.
