DanielWestern
- Reading
I have recently had a room decorated in my old Victorian terrace house, where there is a chimney breast. The wall covering the chimney breast was previously covered with old lining paper so I was not aware of any damp issues. A few weeks after decorating during some cold and rainy weather, some damp patches appeared in the new paint in the chimney breast area. These patches disappear or reduce quite quickly as soon as the weather warms up.
After some reading around I am pretty sure that this is related to hygroscopic salts in the brick/plaster attracting moisture from the atmosphere. My question is, how to address this? I know there is the nuclear option, hack off the plaster and take some of the brickwork out and fix up, redecorate, but thats really not an appealing option if I can avoid it!
Also, I have seen some suggestions elsewhere that this kind of thing might be related to lack of ventilation in the chimney - would that be relevant as well? My chimney is not ventilated I believe, or capped. The damp patches seem surface level only and dry out quite quickly, I would have thought that if moisture inside the chimney was being drawn out through the bricks to the room (which is what I assume ventilation for the chimney would relate to) that the damp would be a lot more pervasive and slow to dry out, but I am a novice so not sure.
Anyway, would any of these solutions help?
- I have seen suggestion that DampStop lining paper over the affected area is a way to mask the problem, but would that just make things worse?
- salt neutralising treatment applied to wall, (i.e. over the existing paint) then prime (+ possibly stain block) and repaint
- combination of the above
- clean chimney flue, add vent bricks in chimney
Or are all the above just dancing around the issue and the only solution is to take it back to the brick, neutralise the salt, and replaster?
Also where is the moisture likely to be coming from?
- moisture in the air in the room is being attracted to the surface of the wall by salts in the plaster?
- moisture in the air inside the chimney is being attracted by salts/soot etc through the brick and plaster of the chimney breast and coming out through the wall and showing on the surface?
Thanks in advance!
Thanks in advance!
