Barefootliving
- Mendips
Hi all
We are renovating a 1915ish stone rubble house. It has not been lived in for 14 years and is just a shell needing complete renovation. It has a lot of damp - we will be removing the external cement render and then render with lime, remove the internal gypsum plaster and replaster with lime, add aco drains to ensure any surface water does not reach the house, remove the concrete floors and replace with a limecrete system. We are hoping this will address the damp.
As we will need to put in a heating system we are hoping to go with an air source heat pump but are aware of the need for good insulation. If we have an insulated floor with ground floor underfloor heating, roof insulation, and new double glazing will the heat produced/insulation be sufficient if we use wood or cork board under lime plaster internally? We had also looked at spray hempcrete but the rooms are very small already for a thick layer of this plus lime plaster and if we used hempcrete externally we would need to extend the roof overhang and replace the whole window units to allow for the thickness of the hempcrete spray plus lime render (the roof looks like the only thing that we can keep right now so reluctant to replace if wood fiber or cork board insulation internally would be sufficient). We have a tight budget so cost is a consideration.
We would probably just put cheap electric panel radiators upstairs if building control requires it (we hope to add solar panels to keep electricity costs down).
Any experience of putting an ASHP/UFH heating in a stone rubble house much appreciated.
Many thanks for your thoughts and advice.
Tamsin
Tamsin
