Hi all,
We have just had a Homebuyer Report done on the house we are hoping to buy. It is a 1910 Edwardian Terrace in Derby, a large 3 bed with 3 chimney breasts and the usual sort of layout. Apart from the usual gas & electric tests which need doing, and a number of half-expected non-urgent items, it came up with the 'urgent' items I've copied below (although the mortgage valuation has been approved regardless).
Can anyone tell me how common these sorts of things are in a house like this? We've never bought an old house before. Is this to be expected with most of them, or have we picked a duffer? And does anyone have advice on solving the sorts of problems identified, or know how much a detailed investigation should cost?
Many thanks!
Simon
Main walls: The external walls contain an engineering brick damp-proof course. Damp was found internally caused by failure of the damp-proof course and further investigations are needed.
Internal walls & partitions: We recorded high damp meter readings in ground floor walls principally to the kitchen and rear living room floors caused by failure of the damp proof course therefore, more detailed investigations are necessary.
Floors: There are signs of wood-boring insect infestation in floor timbers. It is possible that timbers have been treated against such infestation. Guarantees may be available and your legal adviser should check this with the present owner and if they are valid and transferable, see Section I. Woodworm may also be present in hidden areas. Further investigations are required and these should be concluded before exchange of contracts.
Cellar: There is evidence of wood-boring insect infestation in the floor timbers. It is possible that timbers have been treated against such attack. Your legal adviser
should check with the current owner for the existence and validity of any guarantees in respect of this treatment and we refer you to Section I. As the insect
attack could still be active and as any further enquiries could take some time, a specialist report on the infestation should be obtained now. In this way, any possible costs for further treatment will be known before purchase. Further investigations are required and these should be concluded before exchange of contracts.
Many thanks!
Simon
