VoidVoyager
- Scotland
Hi all,
I'm after a bit of advice on how best to tackle repairing a rotten section under the suspended timber floor of my late-1800s stone house in Scotland (photos attached).
It started off with a small damp patch on one floorboard next to an an internal wall (stair void behind ) . After lifting some boards, I discovered a bit of a mess underneath. There was a timber running parallel to the wall, acting as a kind of edge bearer for the floorboards, which was just lying on rubble and dust at one end. This piece was damp and fragile. The main joists run into the external wall on one side.
I've now removed the rotten timber board and cleared away most of the loose rubble, leaving very little support for the new treated timber I've bought to replace it. I'm wondering how best to rebuild support at the corner (shown in photos), where previously it was just rubble piled up. Would it be fine to just use some old bricks and slate?
Also, would it be advisable to put down a strip of DPC plastic between the stone and the new timber?
Another issue is the joist right next to this area, which has suffered rot along roughly the lower half due to prolonged damp contact. It's partly supported by another joist running alongside it but not all the way.I'm looking for recommendations on how best to reinforce or repair this joist given the limited space available. The floor feels quite solid so im not sure if I could maybe leave it as is.
Thanks very much in advance for any advice!
