Lacan07
Skill Builder went off on a rant about lime last month on YTThe same would be said and more for the inappropriate and uninformed approach from ‘skill builder’ to damaging period buildings.
I'm not going to go back and check, but I think I recall quite a few mistakes in that video. I think there was a focus on Hydraulic Lime and talking about the benefits, and completely ignoring non hydraulic lime.Skill Builder went off on a rant about lime last month on YT
I reword what he says and it then makes sense.The blogs on his website contain some odd statements, such as ' rising damp was invented in 1962', 'the UK is the only country in the world with rising damp issues' ' and Holland doesn't use a DPC in their houses.
Is that the one where he spoke to a builder who was using white cement instead of lime?Skill Builder went off on a rant about lime last month on YT
Rising Damp solutions were invented by the chemical industry. In a particular chemical industry boardroom in 1962 actually.
Did you know that in Holland, they don't even have damp courses? True...
Bouwbesluit 2012 – Afdeling 3.6 (Vocht)
This section requires that:
This is the legal basis for Dutch practice.
- Buildings must be protected against rising damp
- Foundations and ground‑contacting elements must prevent moisture penetration
- Materials must be suitable for moisture‑exposed environments
Key point:
The law requires the result (no rising damp), not the method (no requirement for a horizontal DPC layer).
Water can rise up a brick. I've seen it, it happens. So when he says rising damp doesn't exist, I don't think that's what he means.
If you have breathable mortar and plaster and paint and enough exposed wall below your finished floor level on both sides of the wall, then it will dry out before it can rise.
So it's not that it can't rise, it's that there are other design choices in place to prevent it. [I want this on a t-shirt -Matt]
With this frame of mind, and filtering/replacing the words he uses it all makes sense and then seems accurate.
I do genuinely believe my understanding is what he means, but it's not what he says.
Agreed, and too often Skill Builder (Roger Bisby, who, as far as I know, is a plumber by trade and not a builder, conservator / restorer) seems to be promoting products via that platform. The tone of the advice often compares to that of the tabloids.The same would be said and more for the inappropriate and uninformed approach from ‘skill builder’ to damaging period buildings.
The guy is utterly unwatchable. Yet he has a following which is more terrifying.Agreed, and too often Skill Builder (Roger Bisby, who, as far as I know, is a plumber by trade and not a builder, conservator / restorer) seems to be promoting products via that platform. The tone of the advice often compares to that of the tabloids.
Yep, did the rounds. He got his views and interactions.Skill Builder went off on a rant about lime last month on YT
