A
Anonymous
Guest
We are hoping to run a small area approx 25m2 of underfloor heating from a solid fuel rayburn. Has anyone done this and if so any advice? Thank you.
Kel
Kel
geoff said:I've never tried it or heard of it being done; it might be difficult to get the temperature right - i.e. low enough. Underfloor works on a much lower temperature and I'm not sure the lack of control inherent in a solid fuel boiler - you can't turn the supply on and off like gas or oil - means it would not be possible. Perhaps if the rayburn were connected (only) to a thermal store, this could then be used to blend and circulate the water to the underfloor heating as a sealed system (see Heatweb or Gledhill systems). You would still have the problem of being unable to control the burning though - some sort of heatsink to prevent overheating might be needed.
charlie-ia said:does nobody know?
Well, obviously, the underfloor heating goes without saying, but apart from that what have the Romans ever done for us?another_richard said:The Romans could do it, why can't we?
Keycare said:the UFH circuit is supplied from the store directly. There are no motorised valves at all, just pumps and blending valves that are controlled by room stats.
Flyfisher said:Well, obviously, the underfloor heating goes without saying, but apart from that what have the Romans ever done for us?another_richard said:The Romans could do it, why can't we?
charlie-ia said:im just learning about ufh.
are there old fashioned ways of doing it?(1960ish perhaps?)
charlie-ia said:The only time Ive felt underfloor heating was in our maths room at secondary school.Red tiled floor, as hot as a radiator almost, not just background heat.On the third floor I seem to remember.
this seems a lot hotter than "normal" ufh appears to be?
maybe I dont remember right, or it just wasnt supposed to be so hot? you could tell there were hot pipes running through the floor
