HI, have a serious problem with wet interior walls. So the house faces into the weather (south-westerly). Recently had the concrete render removed from outside and had the stonework pointed with lime. These are granite face stones. on the inside the walls were plastered with pink plaster some 25 years ago. One part of wall I have replastered with lime. I can see there is moisture in this part of the wall, but it does not feel wet, but is subject to black spots and mould - made the mistake of putting plastic paint on it. plastic paint on other walls is peeling off because of the wet.
Picture a typical house, four windows and a porch in the middle, that is what we a re looking at here.
There is a porch in the middle of the front wall and I think there may well be issues with the leadwork where the porch roof joins the wall and also where the upright framework abuts the front wall, both potential sites for water ingress.
So inside, there is an issue with damp rising up the front wall of room one as this has a stone floor. It has rotted out the carpet and the skirting board. We have dug a ditch outside of this area to see if we can put in a drain?
The water/moisture is apparent on most of this front wall, all the way up to the ceiling.
Room 2 downstairs on the other side of the porch, this is even worse. Floating floor in this room, still the inside of the front wall is seriously wet. This front wall on the inside is wet from top to bottom. The ceiling has an area of damp adjacent to the front wall.
Upstairs, things are very different, there is no moisture at all on the walls.
So this leads me to some conclusions:
There is an issue with rising damp, but by digging a drain this may help?
There is an additional issue with water ingress from a certain height, say from the bottom of the upstair windows down. Perhaps it could be no drip line on the underside of the cills? Perhaps it is the small groove underneath the wooden window frame (new) that should be filled with lime render and isn't?
Maybe it is the front wall that is just not keeping the water out by stone and pointing? Do I need to take off the pink plaster inside and put lime plaster back?
But, this is not damp, this can be just about running water on the walls.
Any thoughts would be very much appreciated.
