A
Anonymous
Guest
Having got around to removing most of the plaster from the kitchen, I'm slow......
I have found that some of the ends of the beams going in to the walls have rotted away. One in particular is bad, with only a small section left holding it in place at that end.
How should I tackle this?
Some of the other beams have had metal straps bolted to them and inserted into the wall to give them strength. This may be good and strong but to me is not aesthetically pleasing.
I need to remove more rotten wood from the ends of these beams, as it is very flaky, and I thought if a brick or two was removed then maybe it would be feasible to make an Oak piece to bolt to the end of the beam, to make it longer?
Perhaps I could remove some bricks from outside to make it easier to do? We have to remove some bricks etc for the replacement/installation of windows, so it wouldn't be too much extra hassle.
Should I just clean up and fill any gap with Lime mortar?
What's the commonly regarded best practice for this job?
What problems may I face? Supporting the wall whilst removing bricks I think will be the main one?
My Mike Wye Lime DVD arrived today, so that's another hour or so taken up learning how to plaster the kitchen, so there is no need to rush with your answers <IMG SRC="http://www.periodproperty.co.uk/discussing/smileys/smile.gif" BORDER=0 ALT="
If you want pictures, let me know and I'll take some.
Graham
Graham
