I'm trying to understand why I can't heat my radiators with the Rayburn.
My last house had a combi boiler so this is all new to me.
The Rayburn is a oil wick burner. 33" wide Royal with circa 1" pipes coming in/out of it. The unit itself gets up to temperature well. Burner glowing red when on full blast.
It will heat up the cylinder with gravity circulation just fine. Gets the water very hot.
As soon as I turned the pump on that serves the radiators, the radiators all warm for a bit, then everything goes cold.
I assumed that the pump was upsetting the gravity loop as the pipes going in an out of the Rayburn were also now cold.
Here is how the system worked?
So with my infinite wisdom, assuming the gravity loop and pump aren't playing nicely, I converted it to a sort of pumped S plan using a couple of gate vales (with no control on the Radiator loop).
So I now have this:
Gate Vale 1, I leave just 10% open. This is a safety thing should the pump fail. I've checked that it will still heat the tank in this position and it does.
With G1 fully open, pump off and G2 closed, it behaves exactly as it did before, the cylinder heats up well. So I've not broken anything which is good.
As a test I closed G1, and left G2 at 50%, and after an hour or so, everything is luke warm to cold. Even the pipes going down to the Rayburn. How can this be?
I believe the pump is working well because with G2 fully open and G1 at say 10%, there's enough pressure difference to over pump back into the header tank. Keeping G2 at 50% seems to solve this.
But still no real heat.
Does a Rayburn produce so little heat that it can't heat my radiators (5 of)?
All bled, plus I have had heat in them for 10 minutes or so when using the original setup.
Maybe the pump is too powerful and water doesn't have time to heat in the Rayburn, but this seems to break the rules of thermodynamics.
Only other clue is when I drained the system down, and filled it back up again, radiators didn't need bleeding at all. This surprised me.
What am I missing here? Any clues?
Many thanks
So I now have this:
Many thanks
