MetManMark
- Devon
All
We have had dry rot issues (as discussed elsewhere on this forum) and we are trying to get everything ready for the dry rot experts that are coming to treat everything. As part of this we have removed a lot of the plaster and wood that is within spitting distance of where rot has appeared. The house (built in 1777) appears to have 2 courses of bricks starting from the floor and then a piece of wood that is the same sort of size as the course of bricks - then more bricks and then another 'course' of wood at waist height - more bricks and then another course of wood at head and then more bricks (apologies for the poor description but hopefully you will get the drift). We have had to remove some of the timber that was at waist and head height as it had been attacked by the rot. These we replaced by brick (original) and lime mortar. We are thinking what to do about the timber that we have removed at skirting board level. Currently we have wedged in some brick just to stop the bricks above from falling. We are thinking that timber replacement isn't a great idea and that we would replace with bricks & lime mortar. However, our (trusted) builder has suggested that we put in some sort of membrane - presumably a sort of damp course. Is this wise? I was thinking that just replacing with lime & brick would do the trick - I understand that putting in damp course membranes isn't a good idea in older properties that were designed not to have one.
Thoughts please!
Thanks
Mark
Thoughts please!
Thanks
Mark
