I thought I would share some experience of my recent change to a “smart” central heating controller and the quest for lower energy bills.
We have a large house, consisting of three cottages and a barn knocked together, one boiler down one end, 15 radiators and the thermal insulation of a typical stone on dirt period property, i.e. none.
I have therefore opted to fit a HIVE system (British gas / Centrica) but there are other systems out there.
The HIVE system (for heating) is a two phase system.
Part 1 – Thermostat replacement.
This replaces your traditional thermostat or thermostat / timer combo for both your central heating and gas hot water (but not electric immersion heater).
It is a simple plug and play wiring replacement for your thermostat and the controller temperature sensor is a wireless unit that you can put anywhere.
There is also a sophisticated app for your phone to control the schedules of times and temperatures.
This is good, and a simple upgrade, but it still only controls ALL of your heating on/off/temperature. The key being, all, if you switch heat on the whole house heats up.
Part 2 – Smart TRV (Thermostatic Radiator Valves)
These are wireless controlled valves that fit in place of the inlet valve or traditional wax TRV.
The HIVE TRV’s sense the room temperature and you can individually open the valve and switch on the boiler.
This means that you can heat different rooms to different temperatures at will.
Via the app you can then set different rooms to run at different temperature and times.
For example, master bedroom heats up at adult bed time, the children’s rooms at their bed time and the study during the day, with the heating off (or set to 10C for the rest of the day.
Wireless
The system runs on a zigabee network so you need a box to link it into your wifi system. However, you can also get plug in zigabee signal boosters (from HIVE) so you can get a signal all over the house. This ability to boost / extend the signal was important to us due to the stone wall thickness.
Cost
The main controller, including fitting (which I thought would be difficult, but I now know is easy and was bodged anyway) was a fixed £250 from British gas. This was a lot cheaper than the Honeywell system I looked at.
The smart TRV’s are about £50 each which mounts up fast but none of the other systems are that cheap either. I also had to change all the valves as they were so old they were not physically compatible but they may also have been seized so not such a bad thing.
Problems
The early HIVE TRV’s got a very bad reputation, and the control side is still not that logical and a bit glitchy. The official support isn’t that great but the online support community is good.
I also think some users expect amazing results and moan when there room isn’t hot after 5 minutes of calling for heat. I am realistic to know I will never win the heat battle but I just hope to reduce the attrition rate.
Saving
HIVE do not guarantee any savings (some brands do) but I can not help but think that just heating the rooms I need has got to be a saving.
So far I am happy. A lot of control and just to have a warm study you do not need to heat the whole house is great.
Hope this is of interest or helps someone.
Richard B.
P.s. This is not sponsored, wish it was given the cost of the valves! I just thought I would share to prompt any discussion or questions.
