Hello,
As part of my war on damp in our 1850s solid brick cottage, I've spent the last 2 days pulling up crazy paving patio stones in the front garden, as the ground level is a couple of inches hire externally compared to the interior.
Ive got to the stones against the house this evening, to find what seems to be some form of concrete or stone slab against the house, coming out around 1m or so from the wall.
This wouldn't have been a problem, as id still be lowering the exterior a good 15cm all round even at the level of the concrete, but it seems it raises up on either side, clearly designed to channel water into the gulley(which itself just puts out to soil at around 1ft away from the wall.
I fear I already know the answer to this, but am I going to have to pull up this concrete? If so, am I risking unsettling the footings of the house, particularly with power tools?
The plan is to grade the soil away from the property, then gravel over the top of a membrane.
Thank you.
Thank you.
