my_name_is_slim_daisy
- London
Good evening all
I’ve painstakingly removed a strip of woodchip wallpaper to finally start the process of decorating over some electrical chasing. I have some questions at the bottom of my post - I’d really appreciate some advice.
For some background, when I took the wallpaper off I found that a 10cm-wide strip from top to bottom (purple section in one of the attached photos) felt hollow, presumably when the electrician was working on it.
When I chipped away at it (not too much force, enough to remove loose bits) some of it has gone back to brick. I feel I could probably take most of that purple strip back to brick, although I don’t really want to as I’m worried about building up layers of polyfilla onto brick.
My questions are:
- In the areas I’ve gone back to brick, can I use polyfilla + scrim tape? The plaster layer that’s come off was only around 15-20mm. Will the polyfilla adhere to the bricks? Or should I use some form of bonding coat?
- In your opinion, should I force the rest of the hollow plaster off, and build up the layers from brick again (using polyfilla)?
- Lastly, slightly unrelated, but is it a bad idea to use orange scrim tape if I’m planning to paint over it with white paint? In the kitchen I’m fixing up some chasing and I’ll be using scrim + Toupret to strengthen/fill/skim. I’m just slightly worried that after mist coat + 2 coats of durable Matt paint, the orange may still show???
Thanks in advance.
My questions are:
Thanks in advance.
