- Shropshire, England
On one side of Feltwell Towers, built in 1899, is a rather tall 2-flue chimney - on the right of this picture:-
I've got damp staining on the ceiling of the first floor room that contains this chimney breast, and a picture hung on it went a bit mouldy - so it's definitely damp, although an exposed section inside the eaves of the roof above looks fine, and the wallpaper on the chimney breast shows no signs of damp. One flue is redundant - ventilated top & bottom, "pepperpot" cap at the top - and the other is lined for a gas fire that is fairly rarely used.
The chimney breast is not in great condition but it's not bad - it's been cement pointed but it's mostly intact, and there are a few bricks that are spalling - it wants a bit of attention but I've seen far worse.
On the inside face of the chimney, above the roofline, there's a slight projection from the brickwork - looks like slate - that someone has put a fillet of mortar on - looks like it was meant to throw drips away from the face of the brickwork. Has anyone come across this before, is it likely to be a slate DPC that extends all the way through the chimney? Nothing visible from the other side. Here's a picture, taken from my study roof window, unfortunately I'll need scaffolding to get at it up close:-
As you can see the projecting slate looks like it has a bit snapped off at each end. The flashing to the roof should be good - it's only about 12 years old, and I can get directly to the underside of that section, all looks dry, no sign of leaks.
I've always been a bit suspicious of the 2 sloping side sections of brickwork, if they are likely to let water in. I've thought about screwing some treated battens to them and putting roof tiles on them - overhanging the edges by a couple of inches, with flashing into the brickwork above. This is the rest of the chimney above:-
I don't know what the top of the chimney is like, but the roofers I had when the roof was recovered did check the flaunching and reported all was OK. No reason not to trust them but it was 14 years ago I suppose, it could have failed since.
Any thoughts if that slate is likely to be a DPC all the way through, supposedly isolating the stack below from damp from the exposed section above? In terms of way forward I think all I can do is bite the bullet and get it scaffolded all the way round in the spring, rake out the pointing, repoint in lime, and change the spalled bricks. Unsure of what to do with the sloping sections - aesthetically best left as exposed brick but repointed, but if they are the damp source maybe my roof tile idea is worth doing. An identical house on the other side of my town has roof tiles on them.
I'm regretting leaving it a bit late for this year - feels a bit late now to be doing such exposed lime pointing, frosts could come at any time.
