Flyfisher
- Norfolk, UK
Househunter said:That makes sense --- horses for courses, as you say. What model was yours, and what (roughly) does it cost per year to run?
According to my records, DeLonghi DES12, £134.99, John Lewis, 3rd March 2012 (how sad is that?! :lol: )
I don't know the running cost but it's a good question. I didn't notice a significant increase in our electricity bills so I guess it's not too much. Basically, it's just a very small refridgerator. But I recently bought one of these plug-in power monitoring gizmos https://www.amazon.co.uk/Energenie-429-856UK-Power-Meter/dp/B003ELLGDC so perhaps I should check.
Househunter said:I also came across this video, and in the comments below it, the conservation specialist who posted the video effectively stated that dehumidifiers are not a solution. That said, his solution sounded very expensive, and so I thought it might be worth spending a couple of hundred quid on a dehumidifier and giving it a try (I can always sell it afterwards), before spending thousands on something more permanent.
Hmm. So moisture-laden warm air (relative to the outside) from the cellar is ventilated outside on a frosty day and onto a, presumably, freezing paving slab. I'm not at all surprised by the condensation on the paving slab. Is anyone?
Now imagine a summer situation. Warm summer air laden with moisture is pushed through the cellar to ventilate it. The cellar is cooler than the outside temperature so what will happen to the moisture in the air drawn into the cellar? Yes, you've guessed it already. :wink:
As for dehumidifiers being useless, perhaps I should post a video showing the outflow of my dehumidifier filling up a 20 litre water container over a week or two (depending on weather conditions)? That's water being removed from our cellar whichever way you look at it - maybe not by that video poster's preferred method of forced ventilation, but being removed all the same.
I'm not suggesting ventilation is a bad thing, on the contrary, it's generally a very good thing, but there will undoubtedly be times when the outside air is more humid than the inside air, which could cause[/] moisture to condense inside a building, whereas a dehumidifier can never cause moisture to condense inside a building, it can only remove it in a controlled manner.
