Surely the answer is "all of them".The cryptic message on this mornings note reads - "Reclaimed bricks/stones - how many?"![]()
I'm very pleased to hear the wall has met the approval of the First Lady. There have been times over the past three months when a fence would have been a more popular option here.As the First Lady and I were both frequent business travellers and, more often than we would like, to different destinations, we each dropped into the habit of leaving little notes for the other when leaving the house. Whist these began as small billet-doux, after a time they morphed to include little memory joggers or tasks that one would like the other to deal with before the absentee came back home. This morning I was, as always, pleased to find a small note to tell me.. well I won't bore you with the superfluous details... but suffice it to say there was a rather odd and cryptic message that required further clarification - which I have now received. As a consequence I have resolved, yet again, to ensure that I log off completely when I leave the pc at any time. You see, since visiting the Lost Gardens of Heligan many years ago she has had a hankering for a walled garden of her own and clearly she now finds, courtesy of perusing @overlander matt 's building efforts, that the wooden fence boundary I previously constructed for her vegetable garden is no longer suitable.
Thanks Matt.
No! I've only ever made one open ended commitment to the First Lady and she already takes full advantage of that.Surely the answer is "all of them".
That way, you know you'll have enough to build the wall to the First Lady's specification.
I fear disappointment is inevitable! I shall have to have a careful look at how this will all work out given the existing brickwork to the left and below. I think I'm after an easy life.It could be a segmental arch as well. The easiest solution would be to have 2 stopped ends, and lower the wall inbetween to clear the tree. The only problem with that is you will look at it in the future and wish you'd done it differently. Plus you will disappoint all your followers on here.![]()
Maybe having a shape like this as a compromise. Cut the angles to lines, and lay the brick on edge to lines. For the brick on edge at the angles the cut should bisect the angle by half, and the other face should be a whole brick. Work out the brickwork so that all the brick on edge are whole bricks.Thanks for the replies. I'm a bit torn on the best approach...
From a time perspective, I feared that the internal arch was going to be mentioned! I agree it will look good if executed correctly. I'm not sure how best to approach it given the irregular shape and angle of the trunk. There would be quite a lot of brickwork to consider on the existing side. Would you suggest a flatter/larger radius arch rather than more rounded?
I could do with making a bit more progress on the wall before embarking on this one - my wife may not appreciate the distraction!
